Coax seal sucks... And don't use silicone unless its 100% acid free also, otherwise your just asking for corroded connections and eaten away insulation. As far as coax seal that gooey crap is a nightmare to clean off after a few years of exposure, here is the method i use...
Self Amalgamating tape, also known as self fusing rubber tape, or splicing tape, it has a lot of names but can usually be found in the electrical isle of your local big box store.
If your splicing use a couple good quality connectors and a barrel. Take the self fusing tape and start about an inch before the connector and wrap tightly, just stretching it so its about 3/4 of its normal unstretched width, unless the brand you buy says otherwise this works the best on most of them, wrap it so that you also overlay it half the width of the stretched rubber tape and continue wrapping until your an inch past the opposite connector, then go back with a second layer same method as the first, then cut it with a knife or scissors and lay end down.
Now grab a roll of a 3m Super 33 or 33+ electrical tape and start before the rubber tape and cover it to the other end, and then back again with a second layer. You want two layers of tape over the two layers of rubber tape. The rubber tape is not UV resistant, so the electrical tape is just there to protect the rubber tape from UV. Now your done...
I have done this with splices and similarly for antenna connectors, electrical connections, you name it, and coming back years later i have sliced this open with a knife and it comes right off like a solid rubber shell and the connectors inside look like brand shiny new, no coax seal goop to clean off or messing up the threads of the barrel or the antenna's connector, nice and clean.
We use this method on all the repeater sites and never a problem with any connector wrapped like this up in the air on the top of the tower.
