Coax
AWH100
I have been into scanning for about 10 years.I listen to all the bands from public safety to state police 800 trunk systems. I own: BC 996T & 996XT & 396T. I have a Diamond discone antenna mounted in my attic with 35 feet of Belden 9913 going down into my radio room. From there, I have not bought one yet but I am going to buy a Stridsberg MCA204M multicoupler to connect my 3 scanners together to the one antenna.My problem is, that I am going to have the scanners sitting on my desk and connecting the scanners to the multicoupler which will have 3 cable running up to the desk to the scanners. The Belden 9913 as you know is a good size cable and stiff. The distance from the multicoupler to the scanners will be approx 3 feet. I will like to use 3 smaller more flexible cables to run the coax up to the scanners from the multicoupler. If I was to use RG-58 because of it's small size and flexibility for the 3 feet, how much signal am I going to loose ? I am only talking 3 feet here. If not RG-58, what coax will be better for the 3 feet distance that will give me small size and flexibility ?
Thanks for your suggestions.
737mech
Clark County, NV.
You'll be fine with three foot patch cables just try to buy 50 ohm ones.
cabletech
Puget Sound
This subject has been covered serveal times in several other posts before.
Rg142, Rg148, Rg58, Rg6, 50 ohm, 75, ohm. WTH !!!! For any run up to about 3 ft, the small 142 type is more then capiable and up to about 30 ft RG58 is also just fine.
50 ohm vs 75 ohm is also no big deal, I do not understand why the hangups, I use 75 ohm RG 11 for may master reciever system (8 recievers) and even use it to feed a dual band 150/440 ham TX antennna.
If you are going to put a large amount of money into the Stridsberg, the cable will not matter.
If you are really conserned about signal loss, get a 10db cabletv amp and intall AT THE ANTENNA, this will highly reduce signal loss.
LtDoc
Oklahoma
I seriously doubt if you'll notice, or even be able to measure any losses in those short, flexible, cables. It won't amount to anything. Fractional dB loss figures are meaningless unless you have a huge number of them. You won't in your situation.
- 'Doc
n5ims
Standard RG-58 will give you under half of a dB loss for that three foot run. While you can probably measure that amount of loss if you use the right equipment, your scanner won't even notice that. A strong signal will still be strong. A weak signal will still be weak. A very weak signal will most likely still be very weak.
A signal that is so weak that you can barely tell it's there through the noise, but not really make out what is being said may (just perhaps and only if it's really that weak) be weakened enough by that half a dB loss that it's no longer detectable. No real loss here since you couldn't make out the signal anyway.
Radio signals are like water in a bathtub. There's really just three states, not enough, enough, and too much (yes, you can have too much signal).
* Not enough is for really weak signals or the bath water level that's really too low to do anything with. The signal will be noisy at best and not really good to listen to comfortably, the bathtub will be slippery to step into but not good for bathing. This level is where you need to add water to the bathtub or for your scanner reception increase your signal or reduce your coax losses. For a good antenna installation, this condition is generally the exception, probably less than 2% of signal levels would be where adjustments would be required if the antenna and coax selection were good.
* Enough is fine. You can listen to the signal just fine, the water level is good for bathing. This state covers probably 90% of the signal levels (or bathtub water levels). You could add more signal (or bathwater) or even remove some and it won't make any real difference.
* Too much isn't good. For a scanner, you'll overload the receiver and cause issues like images (signals appear where they don't actually exist), the overly strong signals will prevent the weaker ones from being seen by the scanner, or the circuits in the scanner will distort the signal's waveform so it won't be decoded properly. For the bathtub, you'll overflow the tub and have water all over the bathroom floor.
Small changes in signal levels are really meaningless unless it moves you from one of the above states to another. As in the bathwater example, say you fill the tub with water so there's "enough" water in the tub. You get a glass of water, fill it up with water and dump it into the tub. You added water for sure, but can you really see the difference in how full the tub is? Most likely not. You could say the same thing if instead of adding water you removed a glass of tub water. Still no real difference in how full the tub is.
The real issue could be the definition of "small". If you're close to the area where the state changes (enough to too much for example) only a small change may be important (in the bathtub example a cup may be OK, but a gallon may be too much). If you're in the center of the "enough" range, several gallons either way may make no difference at all.
Getting back to the dB loss issue for your scanner, the same rules can apply. "That coax has 3 dB more loss than this one. That's half your signal!!!" OK, while this may be true, if the signal is on the high side of "enough", half your signal may push things down a bit to the lower side of "enough" and since "enough is enough", that loss is OK. (Think a tub 3/4 full of water and you drain half of it out. Still enough for a bath!). Now if that signal level was just a bit above the "enough" level, a much smaller loss level may be important.
Generally though, loss or gain values in the fractional levels (often as much as 1.5 dB) are not enough to change the signal state. As they often say, don't sweat the small stuff really applies here. If the loss is small, don't worry about it!
