Cobra 148 GTL doesn't recieve signal on any modes
Registr8r3344
Abrams11999
Pennsylvania
My Cobra 148 GTL doesn't receive a signal at all, and I don't know why. I transmit on the same channel it's on with another CB and it doesn't receive the signal.
Registr8r3344
Abrams11999
Pennsylvania
Just a bunch of static I'm afraid. When I keyed up my handheld radio next to it, it didn't receive the signal. What I also found odd is that there's no change when I attach an antenna.
And the upper channels, 19 through 40, have nothing but very low static.
New problem, too. Nothing but static when I key up and talk on channels 11 through 40 on the GTL. No voice.
WB9YBM
Where does the signal vanish? For example if the signal strength meter moves, we know the signal's at least getting to the IF stage. If you had a signal sniffer of some type or another, that would probably be the easiest/cheapest way to track something down...
Registr8r3344
Abrams11999
Pennsylvania
Channel 12 is intermittent.. anything higher than that gets worse
I'll try to find another mic
Figured out the problem. Frequency is WAY off. RX and TX.
MindenJoe
Minden, NV
The 148 GTL has a receive enable contact in the microphone transmit/receive switch to enable the speaker audio, perhaps a contact is bad. Try another microphone.
prcguy
Its a part of a receiver which supplies the final information on what frequency it will receive before being downconverted to an IF frequency for further filtering then demodulation. If the local oscillator is not working the receiver cannot convert anything to the IF frequency to be demodulated except for noise. Its easy to check if you have test equipment and a diagram of the radio.
Don't know how to fix that, mainly because I don't even know where the local oscillator is..
Registr8r3344
Abrams11999
Pennsylvania
I only have a diagram of a very similar radio which I also own, the Cobra 148 NW ST Soundtracker. From what I've heard, they're pretty much the same internally.
