Cobra 2000 bring it back!
JayMojave
Mojave Ca
Hello All: Ok here we go with a tread telling the radio manufactures what we want in a base Station Radio.
I suggest the Base Radio be manufactured with the ability to add in modifications and allow easy Trouble Shooting designed in Test Points and a real world test procedure. Radio size not to worried about.
A Great Looking Radio, not some goof ball looking pile. Have a group of testers test the radio and its "Button Ology Friendly" value of operation. Don't allow software engineering to design the "Button Ology" operating functions, have a adult engineering supervisor watch over these folks.
Front Speaker, with plenty of Volume and a optional switch for head phones or speaker.
A really good noise blanker. Optional IF and or Audio DSP board to be added on a later dated as its developed.
A great looking back lighted panel, with adjustable control.
A optional RF Front End with lower noise values.
S-Meter and Transmitter Power Meters, that are big and bright, with optional LED's string.
Optional IF Crystal Filters to be easily added.
A real world RF Gain Control to allow at least -30dB of front end attenuation.
A AGC control adjusting fast or slow AGC, with a real S-Meter calibrated in dB's, that is 6 dB per S-Unit.
Equipment handles on the sides of the front panel.
A Power Supply with a large enough or optional Transformer that can handle some headroom. Or a optional larger transformer. Radio will also run off 12 VDC for a Back Up function if necessary.
More suggestions later as time allows.
Jay in the Mojave
SpectrumAnalyzer
Previously Banned Member
Cobra 2000GTL Comeback? I Only Wish
Your idea holds merit Jay just as long as most of what you ask will be end user selectable options to keep a positive price point for us CB'ers, as it is the only three available CB base stations (The Galaxy & the two RCI's) which don't even offer half of what you ask are going for $400 to $500 so maybe DIY could also be an option too, years back I've known serious radio buffs to totally gut "removed from service" Motorola/GE/RCA trunk mount radios & even early generation digital readout scanners & receivers & refit them into various sized enclosures like these.
Aluminum Enclosure Products & Chassis | Browse Our Selection
Instrument Enclosures | Electronic Instrument Enclosures | Metcase USA
Anyway we can always dream can't we? No harm in that.
JayMojave
Mojave Ca
Hello Spec A: Yeah I am sure I am asking for the Moon here in these options. But the urge fiddle and Modify is out there as you have said. Your modifications sound pretty advanced.
I am also sure that these suggested options would raise the price of the radios to the point where a Ham Radio is affordable. Ok but as Technology marches on maybe these are doable in a inexpensive manner in the further.
A Radio designed with the ability to be modified by the users say using plug in, plug out modules / circuit boards with factory service to assist with modification instructions on a CD or web site would work. Modification of the receiver using DSP for IF Filtering and IF/AF Band Pass would be a big plus. And watch the users come up with many more modifications as time rolls on.
Jay in the Mojave
southern comifornia
why i like the ideas i didnt buy a base specific radio. i got the uniden 980ssb which is 200$ less than the galaxy base. i just cant justify spending anything over 200 on a base specific radio that only puts out 4 watts.
CyberWarrior
Ft Lauderdale FL
Wow I would love to see the Cobra 2000GTL,be made again !
I never could afford it when it was made.
Sad thing is,if you find one on EBay is priced into the ceiling level.
JayMojave
Mojave Ca
Hello All: That would be nice to see a new Cobra 2000 made again.
They would probably make it for 12 and 10 meters as do some manufactures. If it was designed to be modified for the upgrades as said that would be a good feather.
I used a Yaesu FT-902 radio back in the 1980's and it was a totally superior radio over my Motorola Base Radio. Way better receive, less bleed over, tighter receive, it was a joy to operate on all the ham bands.
But as the three leading radio manufactures, Yaesu, Kenwood, and Icom, low end HF Radios are well under 1000 dollars, it doesn't look like its gonna happen.
Jay in the Great Mojave Desert
Blackswan73
Central Indiana
All a Cobra 2000 was, was a 148 and some extra meters with a power supply in a fancy case. Exact same radio as the Robyn520, President Washington, and a couple of other "base" radios. No better than buying a mobile and power supply. Same thing today with the RCI, and Galaxy radios. Just a 2950 in a fancy case with a power supply. I did something similar years ago when I took a Robyn base module and modified it to fit and power a 2950.
