Collin County Public Safety problems
bmxpro822
Monett mo
does anyone have problems receiving it?i have set reband tables i thank i did it right. i have tryed a 800mz antenna still no luck. i have a pro 197
Ensnared
Waco, Texas
Which One?
When I clicked on the Collin County DB, I observed quite a few trunking systems. In order to help you, it would be important to know:
a) what specific system or frequency are you talking about;
b) how you are programming the system, manual or computer;
c) what software are you using if you are programming with a computer.
hiegtx
Dallas, TX
its the ccso and ccFD Motorola Type II Smartnet Collin County Public Safety Trunking System, McKinney, Texas - Scanner Frequencies
i have tryed programming the system manual and computer the programming software is arc500.
Take a look at the ARC500 guide in the Wiki. You need to both enter the correct Custom Tables, as well as "tell" the software to use them. See this section of the User Guide.
If you're still having issues after doing that, then you might upload your programming file by attaching it to your reply. However, the file type used by the ARC software (as well as a number of other ones) is not an allowable file extension to post. You can work around that by "zipping" (compressing) your file before uploading. I use the free 7Zip for that. WinZip is another well known file compression utility, and there are others, most all of which can be found on Download.com
The alternate way to post the file is add an additional file extension to the existing files name. For example, let's say you have your ARC500 file named "PAWM.gr5" (without the quotes, of course). To make the file one you can attach to a post, simply add a valid file type extension to it. (If you look at the "Manage Attachments" area of the forum post editor, you'll see a list of the file types that are acceptable. Just rename a copy of your 'PAWM.gr5' file to 'PAWM.gr5.txt' (again, of course, without actually using quote marks). You can then attach that to a post where someone can take a look to see what's wrong.
I didn't have to use a reband table for CCSO. Just entered the new frequencies and it worked, Same with Dallas.
hiegtx
Dallas, TX
No table was required for the Dallas LG system, since all of the 'new' rebanded frequencies in the 851> to <854MHz range had a 5 in the fourth decimal position.
However, for the Collin County system, five of the six frequencies, all the ones under 854.0000MHz, have a zero in the fourth slot, so tables are required.
Russell
Texas DB Admin
Dallas Texas
I'm using the tables for Collin County as well. At a minimum you should have;
851.0125 0 719 25.0
851.025 440 559 25.0
Russell
bmxpro822
Monett mo
851.0125 0 719 25.0
Russell
sorry for the long long wait but ya thats what i have i just cant here the vary goodits gotin better .. i didet thank i wood have a problem i stay by allen high school but idk still new to scnners..
and by they was sorry for my spilling i have dyslexia lol .
Russell
Texas DB Admin
Dallas Texas
I get tons of static on the CC system here in Allen, as well. They're coverage tends to favor the northern and eastern parts of the county better. They haven't had a tower in the southern (esp southwest) part of the county for many years.
Russell
bmxpro822
Monett mo
ya i guss thats what it is i didet that it wood be that b/c of the jail is not too far from allen... but thanks for the help guys.
