If you are getting any power out on other bands, your radio is likely just fine. Your antenna in that configuration can change it's resistance & capacitance based on many different things (humidity, temperature, water content in your wood fence, the leaves changing color and drying out, etc...). I have found, at times I can squeeze 160m out of my EFHW at low power, and other days it doesn't work, based on other factors outside my control like the weather. Similar to you GR5V, my EFHW is no where near resonant or a good match for 160. Like prcguy said, your antenna is a terrible match on 80m as it is, when the weather makes the match worse, your tuner can't keep up.
It seems the Z-100 did a good job and got you started. I'd second the recommendations above, send it in for repair, then sell it. Buy something "oversized" for your use, consider a factor of safety of 20%. Your 7300 can do 100W, make sure whatever you buy will handle digital of at least 120W. If you anticipate an amp in the near future, make sure you are covered now. 200W amp, get something rated at 240W, 500W amp, get a 600W rated tuner, etc.
