R30 Computer Control software
bearcatrp
Land of 10,000 taxes
Is there any software that will work with the R30 that can control the R30 with your computer with logging or other options? So far, I haven't found any. Thanks.
kc5igh
Velarde, New Mexico
I'm a new and relatively inexperienced owner of an R-30, but I think you may want to take a close look at Icom's CS-R30 software.
I've learned the basics about how to use the software to program the R-30's memory channels, VFO scan edges, and some of the settings, but I'm not yet certain about whether or not it can handle reception logging. It looks like a very feature-rich tool, so my guess is that it probably can. You will probably need to install a microSD card in the radio (pretty simple) to record data (including reception logs?) or voice traffic.
Someone on this forum will probably give you much better information shortly.
Good luck!
N4DJC
Upstate
The only control app I know of is the RS-30 app mentioned in this thread
iMONITOR
Silent Key
S.E. Michigan
ICOM's software is very limited! Check out Butel's ARC30 software:
Overview of options in the ARC30 programming software for the Icom IC-R30 receiver:
  • ARC30 programs the Icom IC-R30 receiver (SD card is required!)**
  • ARC30 includes the most versatile memory editor available on the market including cut/copy/paste options!
  • ARC30 includes a user friendly 'browser' that makes navigating the software a breeze
  • ARC30 is programming software only using the SD card slot**. ARC30 does NOT support audio file and ICF file transfer/conversion nor does it control the Icom IC-R30.
  • Radioreference.com* database import option for conventional and trunk frequencies! Programming your receiver was never this easy!
  • Radioreference built in search option
  • New in 0.93: Autowrite channels editor
  • Edit multiple channels
  • Print option
  • Paste Frequencies directly from any website using 'Paste Special'
  • Setup channels in an easy, spreadsheet type interface.
  • Store unlimited number of configurations on your harddisc.
  • Windows 7 / 8 / 10 compatible
  • All updates are free for registered users
  • Copy/Move/Swap banks
  • Move channels up and down
  • Import/Export CSV data
  • Fill down/series option
  • Full clipboard support for import/export data to/from other applications
  • Enhanced sorting options
  • Remove duplicates / Find duplicates overview
  • 30 day risk free trial period (trial version does not upload data)
  • Cheap and better alternative to Icom's expensive CS-R30 programming software!
[source]
bearcatrp
Well that sucks. Oh well, such a sweet receiver would do well with a software program to control while hooked up to a computer.
