computer won't start
moonbounce
Anyone have any idea why my computer won't start after it has been shut off, doesn't matter if it has been off for 5 days or five minutes. The only way I can start it back up is to pull the plug from the back of the computer case and plug it back in. Some times I have to perform this process 5 to 8 times. Any help would be appreciated. This might force me to buy a new computer which is another whole raft of questions.
TIA Moonbounce.
bad power cord, or power supply going bad?.. are you getting into the OS at all?. whats if/when it does boot up??, Also could be RAM chip going bad also?
moonbounce
I put a new power cord on, made no difference. Once the computer starts, it is fine just when it is shut off there is a problem. Also it has shut off on me buy itself when it was not in use, but it powered back up on it's own.
OS is windows xp pro. but it is on an old computer.
natrixgli
Milwaukee, WI
Try disconnecting any USB devices and see if it starts as normal then. I had a cheap Acer box that wouldn't power up if I had my USB card reader plugged in.
-n8
moonbounce
No new hardware installed, I did disconnect my only usb connection no change. I don't think I want to take the power supply apart, I may never get it back together. I guess I will have to upgrade to something more current like a quad core.
Anyways thanks for taking the time to reply and thanks for you suggestions.
Moonbounce
fineshot1
NJ USA (Republic of NJ)
Have you checked to make sure all of the cooling fans are running or are not plugged up with dust?
PC's will act strange when they get too hot inside.
mike_s104
Berkeley Co. WV/ Loudoun Co. VA
I would blow out the dust (outside) with compressed air (compressor or canned air) or use a good vacuum like a shop-vac with some small adapters to get all the dust/dirt out.
There may be a fuse near the where the 120v/220v comes into the PS; check that. More than that, I would just replace it.
On some older Gateways, if there was a power outage or surge, they would not come on. If you unplugged it and flip the 120/220 switch to the other position, wait 10 sec and flip it back then plug it back up, the PC would come back on. You might need to break a sticker and use a small screw driver to flip the position.
If you can wait, order a power supply tester. I got this one: DealExtreme: $8.52 PC Computer ATX+HDD+SATA Power Supply Tester but it took a few weeks to get. Check Newegg.com for one like this: Newegg.com - Rosewill RPST-24-A-01 20/24 Pin Power Supply Tester - PC Tools .
I would think it would be the power supply like others suggested. No need to get a whole new computer for a $20-$50 part.
It is really a bad idea to use a vac to clean out your computer due to static buildup and discharge. Especially if the attachment has nylon bristles. It is also a bad to take your electric air compressor and use it to blow dust from your computer, for the same reason, static discharge. The safest method is to use compressed air from a can, or transfer air from your compressor to an air-bubble, and it goes without saying to open the valve just slightly, not all the way open.
To clean electrical equipment with any plugged in electrical equipment is a short trip to disaster, as it does not take much static discharge to fry a sensitive piece of equipment such as a computer or radio in very short order.
I doubt this is going to help the OP with his situation, but I hope it helps someone in the future who has the bright idea to vacuum their computer out. Simply put, DON'T DO IT.
mike_s104
OMG...I NEVER mentioned a brush of any type. I have worked with computers for over 20 years and have used a vacuum to clean out equipment from servers to PC to anything else. The little adapters I was mentioning was to reduce the size of the hose fitting from something like a 2" hose to a very small 1/2" size to get into the small areas.
You're probably correct about the static being generated from the motor in the vacuum. If you want to be very technically correct, you should mention using a static strap before diving inside the case.
eorange
♦RF Enabled Member♦
Cleveland, OH
The safest method is...transfer air from your compressor to an air-bubble
How is there any more or less danger of static discharge between these 2 methods?
Ditto with mike_s104, I've always used reducers (never brushes) along with a static discharge strap - which is THE MOST important thing - and I've never had a problem.
Back to the OP's problem - it does sound like overheating.
brandon
SoCal
I had a similar problem a few years ago. It was a faulty power supply.
Swap it out with a new one and you should be golden.
moonbounce
I am also thinking the power supply, right now it has been coming on like normal, I guess I will just have to wait and see and shop around.
mike_s104
If you do end up replacing it and think in the future you might need to add more drives or anything else, you might want to get a PS with more wattage than you have now. If you've added any drives since you started having issues, it might be that the PS is too low for the drives/components you have installed.
K
kb0nly
Guest
I would replace the power supply before anything else. These days you can get a cheap ATX 400w supply for next to nothing. $20-$30 tops.
It may be working now, but beware, i had a similar case last year and then one day the owner came home and smelled smoke, the power supply cooked.
moonbounce
no worries anymore, it quit for good. New problem, I put my windows xp pro original disc onto an old tecra 8100. that computer had windows 98 everything went well BUT, there is always a but, What happens when I register xp pro, being as it was on another hard drive and is now on an old formatted hard drive, will it now be considered pirated?
poltergeisty
Truth is a force of nature
Banned
RLG, Fly heading 053, intercept 315 DVV
moonbounce
In my case, my hard drive crashed, so I can't reformat it. Strange when you buy something, it isn't actually yours. Thanks for the reply poltergeisy.
shaft
Wentzville, Mo
You could just build your own registry file with the product ID, digital product ID, and License info. Once you have that, any new machine you build, move the reg file to your desktop, double click it and let it write it to the registry and your done. No more worries about activation etc... This only works if you have an already legal copy of WinXP installed on a machine.
