2ahuman1791
- Joined
- Aug 7, 2024
- Messages
- 11
I bought a Laird B132S mag base antenna for VHF communications on the 155mhz MURS bluedot and green dot freqs.
My antennas overall height (the antenna to the part that unscrews from the mag base) is 23" inches. My antenna whip measured from the top of the spring to below the ball tip is 18 and 1/4" inches. with the ball tip its 18 and 1/2" inches.
Ive been down a K hole of conflicting info on what length, leaving the ball tip, not leaving the ball tip...but mostly the length to tune it to 155mhz. Based on the PDF tuning chart it says I need to cut it to 16 and 1/8" inches. If you ask the internet youll get 3 to 6 different answers, including calculators. Sources on internet claim wildly different lengths. from 42" all the way down to 17" and in-between.
Heres a photo of my antenna. Ive read you measure from under the ball to exactly where the antenna enters the spring housing with the set screws. Others say measure the ball too. Some say not to. There is no consensus on 155Mhz for metal chrome whips if you search long enough. likewise for where to measure and cut.
Can someone please help me figure out the length on this thing? Its the B132S Laird antenna. it has 2 Allen set screws that hold whip.
