cassidy1190
I just got my PRO-2052 and i am trying to program the NJ state police troop C trunked system into my scanner. The scanner is at the very top floor of the house away from electric noise. I am using the antenna that came with it, and its extended fully.
Frequncies I have of the Troop C trunked system:
856.7125
857.2125
857.7125
858.2125
858.7125
859.2125
859.7125
860.2125
860.7125
867.2125
867.6625
868.1375
866.3125
866.6125
867.2250
868.5125
Here are the instructions i followed...
"1. set the scanner for conventional scanning, then hold down TRUNK until the scanner beebs twince. BANK, TRUNK, and the bank numbers flash"
-ok I did that no problem...
"2. Press a number key to select the bank for the trunked system's frequencies. To select a bank between 11 and 20, press SHIFT then the number keys. The scanner displays one of six system types."
-I selected bank 20 no problem and then the system types came up as expected...
"3. Use up or down to select the system type, then press E."
-I selected E2-800 since troop C is a motorola type II system...
"4. Use the number keys to enter the trunked system's frequncies, then press E."
-ok, I programmed all the frequncies one channel after the other (951, 952, 953 ect.)...
"5. Press either MANUAL or up to select the next cannel in the bank."
"6. Repeat steps for and 5 until all frequencies have been enterd"
-alright i enterd all the frequncies but im not hearing anything not even a little static, just nothing, Im pretty sure i have it in trunk mode and i know for sure that i followed all the instructions and that i have all the frequencies. The broadcast tower is just a little over a half hour away so i dont understand why i cant get the data channel, its probably somthin i did but i dont know. Help!
856.7125
857.2125
857.7125
858.2125
858.7125
859.2125
859.7125
860.2125
860.7125
867.2125
867.6625
868.1375
866.3125
866.6125
867.2250
868.5125
