connecting coax
rickduff
Hastings Ontario Canada
I am installing a discone antenna and would like to avoid running all new coax. What connectors can i use to join the new coax to the existing coax.
Thanks for your time
Rick
joeuser
The Wretched
North Central Kansas
Rick
Whatever the old coax terminates with & whatever the new coax uses... I strongly recommend that you either use the existing as is or, if it will not work, you replace it with new coax. The deal is, every time you add an adapter or otherwise introduce something into your line - you cut down the effectiveness of that line. Example, a single piece of coax, 30 ft long, will out perform 3 pieces of 10ft coax joined together by adapters.
