Connection error with USB Prolific cable.
merlin
DN32su
This seems specific to RPM. I bought a programming cable for the P5400, installed Prolific drivers.
Now I have had some bizzare results including starting RPM, connecting a P5400, turn on the power and the PC shuts down.
The most common fail is "serial port not supported in hardware". First error is "Port in use by another application" That cant be given RPM is the only app installed using serial ports.
This is on a Win 10 machine, and I have gone over every RS232/USB-RS232/and USB setting accessible.
Any one have a similar problem, did you cure it? , What was your fix?
One thing to note, this did work on a previous PC. so very puzzled.
