Connection problem
kd7jfv
Bend, Oregon
Using ProScan v15.4 as the feeder software, has been running for years, no changes that I'm aware of except windows/proscan updates. This error has been going for the last few days.
Error code 10 - Unable to write data to the transport connection: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host failed to respond.
I have called my ISP provider, they did a reboot and reset of my modem, seemed to fix the problem for a few hours and now I am getting booted from the broadcastify server every minute or so.
ProScan
Software Provider
Ontario, Calif.
For some reason the Source Client can't connect to the server.
It could be caused by your computer, NIC card, cables, router, ISP, far end, etc. It's been suggested by a few users to use a tool called PingPlotter to isolate where the problem is.
jstephens1
Belmont NC
did you ever figure out the cuase of this?
mine started doing this today. no issues hitting the server
Code:
C:\WINDOWS\system32>ping audio9.broadcastify.com
Pinging audio9.broadcastify.com [169.44.67.103] with 32 bytes of data:
Reply from 169.44.67.103: bytes=32 time=41ms TTL=51
Reply from 169.44.67.103: bytes=32 time=31ms TTL=51
Reply from 169.44.67.103: bytes=32 time=35ms TTL=51
Reply from 169.44.67.103: bytes=32 time=37ms TTL=51
Ping statistics for 169.44.67.103:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 31ms, Maximum = 41ms, Average = 36ms
jstephens1
Belmont NC
scanner cast does the same so it's not a proscan issue
Code:
Message: Unable to write data to the transport connection: An established connection was aborted by the software in your host machine.
Source: System
TargetSite: Void Write(Byte[], Int32, Int32)
StackTrace:    at System.Net.Sockets.NetworkStream.Write(Byte[] buffer, Int32 offset, Int32 size)
   at ScannerCast.ScannerCast.PushClientThread()
--Message: An established connection was aborted by the software in your host machine
Source: System
TargetSite: Int32 Send(Byte[], Int32, Int32, System.Net.Sockets.SocketFlags)
StackTrace:    at System.Net.Sockets.Socket.Send(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags)
Socket error: 10053
27-Dec-2019 11:05:02    Connection complete to RR server audio9.broadcastify.com/07zrtgxpwj48
27-Dec-2019 11:07:39    Write to Icecast server failed Unable to write data to the transport connection: An established connection was aborted by the software in your host machine.
27-Dec-2019 11:07:39    Disconnect details follow (for debugging if necessary):
Source: System
Source: System
Socket error: 10053
27-Dec-2019 11:07:49    Connection complete to RR server audio9.broadcastify.com/07zrtgxpwj48
kd7jfv
Bend, Oregon
I called my ISP, told them I was having intermittent disconnections from their service. Told them I had a program that was notifying me every time I was disconnected. They did the typical reboot of my modem, unplug the modem etc. Eventually they put in a "trouble ticket" and were scheduled to come out and check my end of things but called me a day later stating they found a problem in their hardware someplace. Was fixed in a few days.
Ben
