Connection to car battery
BinaryMode
Banned
2600 dialtone blvd
For that thread stud terminal I'd personalty go with a 3/8" or a 5/16" (which ever the case may be) ring terminal. These are typically UNC (Unified Course).
gro34wser
I’ve never tried the ratchet type. I use an older version of these at work. Very easy to get a positive crimp every time.
Out of the shop I use tools similar to the ones I linked above. Not ideal for everyday professional work but much better than the pocket knife and pliers work I see on customers vehicles.
I have used a variety of different clamping pliers, both ratcheting and standard. These Snap-On are by far the best I have ever used. I can control the crimp, it usually doesn't damage the insulation and the long handles can give you a lot of power if you want it. I used to do a lot of wiring work on commercial trucks and trailers, and the for important things like this I use terminals that have a shrink wrap insulator that you heat after the crimp, and I also dip the bare copper portion of the wire in die electric grease before installing in the terminal.
