control channel programming
crayon
RF Cartography Ninja
36°33'01.2"N 98°56'40.1"W
The short answer to this question is .. yes. :)
Then only problem is that when you are scanning trunked systems .. conventional frequencies will not be scanned as long as the radio can hear the trunked systems control channel.
rdale
Lansing, MI
What type of Motorola radio? Wouldn't that make a difference? We have a W7 and I thought there was an option to put in conv freqs?
JoeyC
Senior Member
San Diego, CA
The scanner will ALTERNATE between the trunked system and the conventional freqs. As long as the trunk system stays active (depending on whether you are listening to programmed IDs or searching all IDs) it may take a while before the conventional freqs are sampled.
rdale
Lansing, MI
Gotcha... Well in that case it'd depend on what scanner it was because the original Trunktracker I didn't.
