Control Channels
6211A
Delaware County, PA
In New Castle County, DE, they use a Motorola Type II system, and the only transmissions I hear are on the control channel. Is that normal? Can I either delete or lock out the other channels?
Mozilla
South Florida
Scanning
What are you using to listen to them.. a radio, scanner ??? A model number, if its a scanner would help us to answer some questions.
DELCOLHFC
S.E. PA
Jay,
When scanning TRS's on the Pro-96 all that is needed are the control channels, you can delete all the others and help to speed up your scan cycle. All the the traffic on the system will come in on the control channel in "open" (+) mode and only the programed TGID's will be recieved in "closed" (-) mode. What you are seeing is normal.
I hope this helps.
54-9A
6211A
Delaware County, PA
DELCOLHFC said:
Jay,
I hope this helps.
54-9A
Thanks Tom!
6211A
Delaware County, PA
Re: Scanning
Using a Radio Shack Pro-2096 and a Uniden BCT795D
