BCD325P2/BCD996P2: Control Channels
Jking1103
I am having an issue with my scanner always searching for a control channel. Or, Finding Control Channel. I have it programmed the way it is supposed to be, the area I am scanning is in Charlotte NC. It will work great, and then all of a sudden it just drops out. I have no clue in how to fix it or what to even check to fix it. The control channels were put in first, all the scanner frequencies are input and the channels are in there and labeled. The sites are correct. The groups are correct.
ofd8001
Louisville, KY
"Finding Control Channel" means you are holding on a talkgroup for a trunked system and the scanner is unable to receive a control channel for the system. This can happen for several reasons.
You have moved out of range for the site
There is something that is blocking/desensitizing the scanner so an incoming signal is not received. Could also be an antenna issue.
The system is using an alternate frequency for the control channel which you do not have programmed.
There could be other things owing to what model scanner you are using.
My first steps would be:
Confirm all frequencies for the closest site are programmed, not just those identified as control channels.
Check antenna connections
Do a weather scan just to confirm the scanner is receiving.
tvengr
Well Known Member
Baltimore County, MD
If you are seeing signal bars but getting the message, you may be dealing with simulcast distortion in some places.
I agree that you are probably suffering from simulcast distortion. That is a common cause of an intermittent control channel. The Mecklenburg County site on the Charlotte UASI trunked system is simulcast.
RFSSSiteNameCountyFreqs
1 (1)001 (1)Mecklenburg SimulcastMecklenburg851.2375851.700851.8125852.0875852.2375852.375852.8125
852.9125c853.100853.2625c853.350c853.8125c855.4875855.7375
855.9875856.2375856.4875856.7375856.9875857.2375857.4875
857.7625858.9875859.2375859.4875859.9875860.2375860.4875
860.7625860.9875
tvengr
Well Known Member
Which scanner do you have? The Uniden SDS100 handheld and SDS200 base/mobile are the only scanners specifically designed to receive simulcast sites. Any other scanner may or may not work depending upon your location in relation to the towers.
ofd8001
Louisville, KY
If the issue is Finding Control Channel, it isn’t simulcast distortion. You gotta be locked in on a channel before distortion can happen.
tvengr
Well Known Member
Not true! The scanner may not be able to detect a control channel at all due to simulcast distortion. If the scanner is unable to decode the control channel due to the out of phase signals, it will not recognize the frequency as a control channel and give the Finding Control Channel message. Simulcast distortion affects control channels also.
tvengr
Well Known Member
Finding Control Channel = the scanner is unable to detect a control channel on any of the frequencies programmed for that system. This is either because you are out of range of the system or you don't have the correct frequencies programmed.
What Paul said is true but failed to mention that simulcast distortion could prevent detecting a control channel. The thread is from 2016 when P25 simulcast systems weren't as prolific as they are today. The SDS scanners were not introduced until 2019 and were designed specifically to mitigate the effects of simulcast distortion.
ofd8001
Louisville, KY
Probably the best thing the OP could do is take the scanner near a site, perhaps 1/4 mile away and see what happens.
Still see finding control channel: programming issue.
Not seeing finding control channel: I learned something new.
tvengr
Well Known Member
I
I agree. My BCD396XT usually shows NFM on my local simulcast system and occasionally the control channel frequency pops up and then goes away again. I cannot get a good lock on the control channel and the audio is all garbled. The Uniden SDS100/200 scanners and the Unication G4/G5 pagers are the only radios that will work at my home location. As long as I have been programming scanners, I still continue to learn something new.
Jking1103
I use a BC325P2 portable scanner. I just purchased another antenna but when I use it I am all over the city being mobile usually. Even sitting still in places it will do it. I have an external antenna but honestly, the cheap included in the box antenna worked better.
Jking1103
I updated all the frequencies and control channels to what is listed on here, same issue no matter what I do. I will try the new antenna when it arrives.
ofd8001
Louisville, KY
Can you try a weather scan to see if the scanner receives?
Are you able to take the scanner close to a site?
Any chance a radio may have been transmitting close to the scanner, or perhaps a static electricity spark happened when touching/connecting the antenna? (That can fry a protecting diode, which unfortunately I have done).
Jking1103
So, my other banks with analog channels and other P25 frequencies are working fine. No issue and no interference.
And as far as spark or static, I don't recall any. The scanner is almost new, I've only had it a few months.
wtp
Port Charlotte FL
squelch on 2 ?
for the weather check...
when scanning, hit the hold button, type in 162.4, hit the hold button.
if that one is quiet, try hold, 162.475, hold.
tvengr
Well Known Member
That is a typical symptom of simulcast distortion. A better antenna increases the number of towers and out of phase signals you receive and degrades control channel decoding. A worse antenna decreases the number of towers and out of phase signals you receive and improves control channel decoding. Try turning on the attenuator. Remove the antenna and replace it with a paperclip. Your scanner will probably work better. When dealing with simulcast distortion, less signal is more.
hamstang
Charlotte NC
I've been monitoring the Charlotte-Mecklenburg UASI system for many years. I can tell you from experience, the Uniden SDS scanners are the only scanners that work for me on that system. I bought an SDS 200 about 5 years ago and was amazed at how much I had been missing.
