Control data channel issue
scannerman200
North Central Alabama
I was monitoring a trunking system this week and all of a sudden, the ctrl channel on this system started making racket. it started yesterday and is still doing it. What should I do? is there another data ctrl channel?
DickH
For some reason, it stopped trunking. Try re-programming the system.
scannerman200
I reprogrammed it, I think the ctrl channel was changed. After research, the ctrl channel can change each day. The agency can switch to a diff repeater. 860.2625 is the ctrl channel that I had programmed. Any idea what the other repeater is?
Comint
Queensland, Australia
Look for the other frequencies in 1MHz steps away from that frequency (can be up to four Control Channel frequencies, if it is a Motorola system).
Comint.
DickH
If the control channel changed, you would not hear it unless it was programmed as FM, not MOT or ED.
Since I don't know where you live, I have no idea what the "other repeater" is. Since it's a trunking system, "switching to a different repeater" doesn't make sense.
If it is a Motorola system, it can have up to 4 CCs. Some systems change CCs often - others almost never. You should make sure you have ALL the CCs programmed.
DickH
Comint.
That 1MHz step might be true in OZ, mate, but here in the U.S. it can be anything.
For example, the CCs in my sytem here in Portland, OR are; 858.7125, 858.7375, 859.2625 & 859.4625.
dangitdoug
Check the database for the system you are monitoring. It will give you the CCs in red and blue. Be sure you have all CC frequencies correctly programmed and moded.
Doug K
cristisphoto
First OFF, what scanner are you using???
It would helpo helluva lot IF you told us what scanner you are using??
Cause Ratshaks the bank must be set on the MO mode or it wil only make that racket in which you are reffering.
Whera the Uniden's Usually have a use the CC only and it will AUTOMATICALLY decode for you...
Anywyas
SO yeaH what are you monitoring with???
Crista
