I have some XG-100 (both portable and mobiles). I have noticed a few things that seem odd, and I'm looking for clarification (under appropriate license usage).
P25 conventional programming, simplex use. I have a system, and assign a TG list to the system, but don't assign a TG, it appears to pull the first TG in the list on the screen, and lets me "change TG", but it doesn't seem to transmit on that TG, simply as "1" i.e. none. Is that normal? Do I have to assign the talkgroup to the frequency in order
Secondly, the encryption/clear switch doesn't seem to work under any scenario. I noticed that encryption is off all the time unless I assign a global encryption key to the system, then its on all the time. Cycling through TG does change which key is used, if a key is assigned to that TG. Is this related to the above "none" TG.
Am I missing something? I'm sure I am missing some best programming practices.
