It's early
That sounds like what I am looking for. Any good references you would suggest for instructions on how to do that?
Out of the stuff I found real quick on the net, here's about the best pic I could find. (don't use the lengths in the picture).
http://www.qsl.net/va3iul/Antenna/Wire Antennas for Ham Radio/47-Vertical_Sleeve_Antenna_for_10m.jpg
Basically, take about 20" of outer insulator off the end of a piece of coax, without nicking the outer braid.
Push the braid back over the coax, so it looks like in the picture.
The center conductor will be about 19" long. Nip at it about a half inch at a time until you get a good match.
You don't need to trim on the outer conductor after you've folded it back. In my opinion, it works better if it's about 10% longer than the center conductor anyway. Just trim the center conductor to match.
Cover with heat shrink, make sure water can't get in the end, a little dab of rtv in the end before you put the heat to the shrink, and you're good to go.
There's probably better pictures and descriptions on the net, but it's early yet.
These also make great rubber duckie antennas. I use a setup like this on my 440 Trbo handheld. Great gain. I've also used these on forklifts at work. No more breaking off an antenna 'cuz they didn't raise the door high enough.
