Correct setup in DSD FastLane for TIII Site file
mtaylor334
Sydney NSW
Hi there
I am new to DSD+ Fastlane and can find little information on Australian trunking in RR. It is mostly years old.
I am trying to add some sites' information when using DSD+. I would appreciate it if someone could advise the correct protocol for the following information that I can see in DSD+
TIII (MOT) Site H2-11 DCC:1
Thanks in advance
mtaylor334
Sydney NSW
Thanks for that. My question is still how do I import that information from RR to DSD+ so that the site name (eg GPT) shows at the bottom of the DSD+ screen rather than Site H2-11?
Kazzaw
South East QLD, Australia
Read the notes.txt file for that info. I think from memory you will have to add it to the .networks and .sites file.
There is no direct import functionality from the RRDB (yet) for DMR systems. If you give me a bit, I’ll share my config with you
mtaylor334
Sydney NSW
Much appreciated Kazzaw. I hope to be able to add some updated info for Sydney based sites/systems.
Cheers
cg
Connecticut
When I am adding a new system to DSDPlus, I try to always do it in the same sequence so I don't forget stuff
Network (or Systems)
Site
Frequencies
Groups
Radios
For example, if you open the .NETWORKS file in a text editor, You see at the beginning:
; line format: protocol, networkID, "network name"[, TIIIareaLength]
So it is telling you what to enter to create an entry:
TIII, 2, "Orion Network" (the area length is for Hytera I believe)
Each of the files has the line format at the beginning. You can look at the examples if there are any or any previous entries
