Because actual Motorola radios are purposely designed not to unmute when RAS is in use and the radio does not have the proper RAS key programmed in, basically to stop you from buying a radio on eBay and using it to listen or transmit on the system. But the actual voice call transmitted over the air is NOT encrypted. Scanners and decoding software don't care if there's RAS or not and will decode the audio so you can listen.Then why does it render a Mototrbo radio without the correct RAS key, unable to monitor it without the RAS key? If it were simply to keep unwanteds from being able to use the repeater, then it would have no effect on monitoring / receiving
