I sincerely doubt I'd get more than 10 sites cleanly from here. Based upon what you're telling me, you must be up pretty high - I'm totally impressed with your coverage from down there.
Looks like I'm a few miles south of MikeyB (at ~6000ft). With the exception of two sites, I'm receiving the first set at 99% with 4 to 5 bars. Have yet to check the second set, but will to see what they offer. I picked up Win500...
Adams County Simulcast - 772.99375
Arapahoe Admin - 853.2375
Buckhorn Mtn - 853.2625
Chevron - 853.8375
Dakota - 853.4625
DRDC CF - 853.9625
DTB - 853.7000
Lookout Mtn - 853.7750
Mt Thorodin - 853.9750
Riley Peak - 853.9125
Smokey Hill - 853.8750
Franktown - weak
Silver Heights - weak
Araria Campus - 770.40625
Betasso - 853.9500
Deer Trail - 853.9375
DRDC DF - 853.9625
DTB - 853.7000
Ft Lupton - 773.41875
Gunbarrel - 774.88125
Hoyt - 774.79375
Kiowa - 774.56875
Longmont - 774.20625
Mead - 853.9875
Ramah - 853.2875
Squaw Mtn - 853.8500
State Capitol - 770.18125
West Creek - 853.9375
Zap - 853.5125
: said:
You want to hear the "hot calls", and paring down to the first couple in each department might do just the opposite for you. Some of the most entertaining stuff occurs on the lesser used channels for many agencies. Many agencies will switch all traffic for some "event" off to one of their TAC frequencies so they can have dedicated air time and not clutter up the primary channel. Wouldn't want the SWAT guys interfering with the guys giving out tickets, right? <g> So do be judicious in your paring of some of the agency channels, most particular those of any LEO channels of interest to you.
If/when I hear a hot call, which can lead to those types of situations, I switch to a Fave on the HP-1 containing the full set of freqs including TAC and SWAT, etc. for that system. (I caught the barricade situation in Lakewood the other night.) Otherwise, the primary list contains mostly disp/ch1, (but all Denv PD disp ch's) while the secondary contains city wide and Ch3, 4, 5, etc. When things are hopping, only primary is enabled, and when not, the secondary gets enabled.
IMO, it'd be nice if we had an app with the ability to control two scanners simultaneously to act as one. For example, with the HP-1 and 197 both scanning the same list and occasionally landing on the same transmission, it would be nice to have a way to tell one of them to continue scanning. I'm sure we could come up with a few more reasons to have this feature.
: said:
I'm not after comprehensive scanlists as much as I am, like you, trying to find the nuggets. Many of the most interesting happenings light up a particular talkgroup very infrequently. Knowing where they can be found is of interest. For example, as I'm cruising down I-25 from Ft. Collins towards home, if there's something on Longmont's SWAT TG, I'd like to be listening to that on the way, and so it's programmed as a priority TG for both the Mead AND the Loveland sites.
True, and it's an excellent idea for another exclusive scanlist! Edit - removed -> which would cover the concerns you mention above!
: said:
Chuckle - the wealth of sites you can hit turns out to be a curse! You've got a lot more paring down to do than I have. My objective in all of this has really been to pare down the total CCs I'm scanning by determining the minimum number of sites required to cover the geography. In that sense, I think we're working towards pretty much the same goal.
I agree. It takes a while, but I eventually come around to others way of thinking...
: said:
FWIW - I'm still working only 5 sites on the base rig, and have managed to suck up 933 blocks so far, and that leaves me with 919 available. Then again, the home rig has every TG that has affiliated with any of those 5 sites, and you can't "share" a TG instance between TSYS -- each is a unique entry.
Sounds like you have plenty of space, especially if you get another 197. I could use another scanner for fire/EMS, but wanted to wait to see what GRE/RS/Uniden's offerings were this round. With the ability to monitor most everything already with what we have, however, I'm not sure there's any reason to wait other than to hope for another price drop when RS releases their version of the PSR-800.
I should take the opportunity to mention here that another reason I bought ARC500 was that it was recommended by Paul, the Douglas/Elbert County live feed provider, who was kind enough to share his complete list that was nice to have when I got the 197.
Gotcha on the duplicate TG's on the same system. Wasn't sure how the scanner handled those...and no need to consolidate TSYS's.
: said:
Sooner or later I'll pare down the base rig as well. For the mobile rig, I really didn't have any choice but to do so early on. I've got a different problem there since I'm running an old Pro-2096 in the car, and it doesn't approve of 700MHz post-Nextel frequencies. That's made picking and choosing a lot more entertaining. Guess I should break down and pick up another Pro-197 (aka GRE PSR-600) for $299 while R.S. still has the refurbs available. Like I noted before, the refurb I bought didn't have a mark on it. Looked like it had never been used.
It being cute and all, it almost sounds like you could use an HP-1 for the commute.
Edit: What's the significance of your avatar?
