cp150 question
markandjere
Franklin County, PA
I have found a local entity using Motorola cp150's . I am trying to search for the frequency that they are using. Are these radios pre-set with frequencies? I'm not even sure if they are using uhf or vhf at this point. I see that the cp150 is capable of using the 146-174 range as well as 438-470 range. Can I narrow the search fields somehow to ease the search process as in removing the Amateur ranges and others?Thanks for any help..........................
KG4INW
Midlothian, VA
They're programmable to any frequency in those splits. Can you see the antenna? Shorter will be UHF and longer, relatively speaking, will be VHF. Or, if you can get your hands on one, the model number will definitely tell you what band they're for.
markandjere
Franklin County, PA
I will try to get a better look at the radios. One radio had a short antenna and another was longer. I will need to do some more investigating.
birdieboy
UHF can be short and stubby or long and skinny. If it is VHF then it will be long and thick. If you know the agency that is using them then you can search for them in the ULS system on the FCCs website.
Tom
markandjere
Franklin County, PA
I would lean towards UHF then ,I did see short and stubby and long and skinny. Now to just get lucky with them using them while I am searching on the scanner. Another thing I noticed was a ComPros sticker on the radio but I haven't found a FCC listing that I can say is the correct info for this location........
KG4INW
Midlothian, VA
True, I'd forgotten about the wideband UHF antennas. Is ComPros a dealer? If so, that probably won't yield much info regarding a license. The MSS I work at puts stickers on most radios we sell, much like a car dealer puts their name on vehicles.
62Truck
Ordinary Subscriber
Ø
What is this entities name?
chrismol1
An FCC license search could produce possible find
markandjere
Franklin County, PA
ComPros is a communication co. here in town . I believe they are associated with Hilltop Tower Leasing.............They've been around as long as I can remember. They also have a location in Altoona Pa. I have done a few searches but found nothing so far .....
markandjere
Franklin County, PA
Location #6 465.275 , I will check that freq. out. That MAY be the water treatment plant along RT. 30. The others are used for boro services gas ,water,etc I can verify 453.250 as active. Thanks.
markandjere
Franklin County, PA
Found the pool frequency.......I wonder if security shares the freq? Time will tell. Thanks guys. Should this thread be closed since it drifted way off topic?
