CP185 Question
threid
Gulfport, MS
I am getting 6 CP185 for my manufacturing plant. I have been told by the salesman that if I needed to make an emergency call that needed to go out to all the radios at once that I could do this -- no matter which channel the other radios were set to at that time. However, I couldn't find any instruction in the user manual that would indicate how this could be done. Does anyone else know how to make this happen?
Luis_R
Wirelessly posted (Mozilla/5.0 (Linux; U; Android 2.2.1; en-us; T-Mobile myTouch 3G Build/FRG83D) AppleWebKit/533.1 (KHTML, like Gecko) Version/4.0 Mobile Safari/533.1)
The CP185 is low tier radio which doesn't have emergency options. Now technically you could set up all the radios for scan and make 1 of the channels priority for all the radios. But this creates an issue more than a solution imho. Cause now you have to make sure all the radios are in scan mode, since this radio doesn't do auto scan ( a feature that causes the radio to automatically scan a certain channel or channes ) as well as the radio isn't smart enough to remember to stay in scan if you switch channels, so you have to remember to put it back into scan mode.
Luis_R
davidgcet
yeah, the only way to do it is key up and scream emergency. are you sure you are not confusing options from another radio he may have mentioned?
kb32
You have need for more than 1 channel with 6 radios?
I would think a main channel and a couple of spares tops. It does have the ability for 16 channels though.
Usually after a couple dozen radios is when you need multiple channels, wouldn't you say so b7spectra?
