CP200 Revisions, Codeplug Programming
WD2AGQ
Hannibal, NY
Is the revision number R03.xx up to R06.xx found on a sticker behind the battery like a hardware version and the codeplug number found when preforming a read something like a firmware version? What I would like to know is can the revision R# be brought up to the latest and greatest revision and if so does it have to be done incrementally? Also, when a codeplug is in need of being saved before a programming with a later revision programmer how does one go about saving the codeplug? Would you save the codeplug using an earlier revision first? hence incremental programming? I have looked for stickies on general programming but came up zero.
gtaman
TACSAT
GALAXY 19 91.0° W
You just like me. I have no clue on how code plugs work. But I can tell you that the radio rev firmware is what is was booted with. Mine are 3.01 I think I don't know how to update them. But since they are updates I believe you can do the latest one without going thru each update. But updating may make you have to reflash the radio. I really don't see why it's worth updating.
