CPDLC decoded with dumpvdl2
AirScan
I haven't been following CPDLC decoding that closely but noticed recently that dumpvdl2 has the ability to decode the actual ATC instructions. Is this the first program that can do this, or are there others that can decode the ATC instructions as well ?
https://github.com/szpajder/dumpvdl2
Some examples ....
[2018-06-25 17:02:41 CEST] [136.975] [-17.8/-48.6 dBFS] [30.8 dB]
2B86F7 (Ground station, On ground) -> 461F64 (Aircraft): Command
AVLC type: I sseq: 2 rseq: 3 poll: 0
X.25 Data: grp: 11 chan: 255 sseq: 0 rseq: 1 more: 0
CLNP PDU, compressed header:
COTP Data:
00 a8 0f a3 30 17 68 e5 97 0f 0a 80 1d 62 2d 0a f5 e2 bc 1a 54 ed 41 af 06 0c 38 60 70 5c 83 ea 1e 98 fc
CPDLC Uplink Message:
Header:
Msg ID: 7
Timestamp: 2018-06-25 15:02:40
Logical ACK: required
Message data:
CONTACT [unitname] [frequency]
Unit name: EPWW, WARSZAWAACC, center
VHF: 133.475 MHz
[2018-06-25 17:02:49 CEST] [136.975] [-34.1/-49.3 dBFS] [15.2 dB]
461F64 (Aircraft, Airborne) -> 2B86F7 (Ground station): Command
AVLC type: I sseq: 4 rseq: 4 poll: 0
X.25 Data: grp: 11 chan: 255 sseq: 2 rseq: 2 more: 0
COTP Data:
00 a7 26 4f 31 87 2c b8 78 58 00 00 81 d9 13 38 74
CPDLC Downlink Message:
Header:
Msg ID: 6
Msg Ref: 7
Timestamp: 2018-06-25 15:02:48
Message data:
WILCO
[2018-06-25 07:29:04 CEST] [136.975] [-18.4/-47.6 dBFS] [29.3 dB]
2B86F7 (Ground station, On ground) -> 461F97 (Aircraft): Command
AVLC type: I sseq: 1 rseq: 7 poll: 0
X.25 Data: grp: 11 chan: 255 sseq: 1 rseq: 2 more: 0
COTP Data:
00 a8 08 13 29 59 02 96 5c 15 d0 c0 14 4a 51 00 8a 1a 53 80
Header:
Msg ID: 8
Msg Ref: 5
Timestamp: 2018-06-25 05:29:03
Message data:
CLIMB TO [level]
Flight level: 360
[2018-06-25 08:01:47 CEST] [136.975] [-28.5/-46.9 dBFS] [18.4 dB]
10920A (Ground station, On ground) -> 4AC962 (Aircraft): Command
AVLC type: I sseq: 0 rseq: 1 poll: 0
X.25 Data: grp: 11 chan: 255 sseq: 6 rseq: 7 more: 0
COTP Data:
00 a8 09 83 2c 28 e5 97 06 06 f0 12 82 44 8b 36 7d 02 01 8e 4b 75 f0
Header:
Msg ID: 7
Timestamp: 2018-06-25 06:01:47
Message data:
PROCEED DIRECT TO [position]
Fix: DEMOP
[2018-06-25 11:47:23 CEST] [136.975] [-18.8/-49.5 dBFS] [30.8 dB]
2B86F7 (Ground station, On ground) -> 424335 (Aircraft): Command
AVLC type: I sseq: 2 rseq: 7 poll: 0
X.25 Data: grp: 11 chan: 255 sseq: 2 rseq: 5 more: 0
COTP Data:
00 a7 83 28 28 a5 97 09 bd 60 2f 8e f2 06 fc 0d 34 b0
Header:
Msg ID: 5
Timestamp: 2018-06-25 09:47:22
Message data:
FLY HEADING [degrees]
Degrees (magnetic): 240 deg
AS
D
DaveNF2G
Guest
Note that this is a Linux program and there appears to be no Windows port.
daniglikmanas
São Paulo - Brasil
Yes, this program is for Linux only. It would be very interesting if they could develop the CPDLC decoding for JAERO or Planeplotter, and in the latter, in addition to decoding the messages, put them in scope.
AirScan
Just got dumpvdl2 up and running using a SDRPlay-SDRduo. Using Linux on a dedicated laptop.
This is the only program I've seen that can decode FANS-1/A CPDLC messages. CPDLC use for enroute operations started this summer in the US on a test basis in a few select Centers. You can follow the progress here ...
New Operator Documents | Data Communications Integrated Services
http://dcis.harris.com/sites/default/files/En Route CPDLC Site Activation Map_20180730.jpg
dumpvdl2 decode example ...
[2018-09-15 03:28:20 EDT] [136.975] [-22.8/-50.7 dBFS] [27.9 dB] [-2.1 ppm]
10307A (Ground station, On ground) -> 78086C (Aircraft): Command
AVLC type: I sseq: 1 rseq: 1 poll: 0
ACARS:
Reg: .B-2031 Flight:
Mode: 2 Label: AA Blk id: I Ack: ! Msg no.:
Message:
/YULE2YA.AT1.B-2031211DC51D6B367CEA94A2C19817D320E180
FANS-1/A CPDLC Message:
Header:
Msg ID: 2
Timestamp: 07:28:20
Message data:
CONTACT [icaounitname] [frequency]
Facility Name: MONTREAL
Facility function: center
VHF: 133.025 MHz
If anyone else is decoding CPDLC in North America I'd be interested in seeing some logs from different areas. Please PM me.
Thanks,
AS
