CPS 16 Build 823-Error 1646
TifosiDonny
Hi all
I have successfully installed CPS 16 Build 823 on my laptop (Windows 10 Pro 64 Bit and it up-to-date). When I tried run it, it always showed me error 1646. I have tried uninstall the software then reinstall it and run as administrator, but it still showed me the same thing over and over again. Any one has solved this problem? Every help will be greatly appreciated!
Best regard
Ant9270
The Green Weenie
What CPS? MotoTrbo?
This is often caused by a lack of permissions to create the below folders. The fix in this case, is to install and run the CPS as an Administrator.
There could also be an issue with Windows (specifically the WMI Service). Make sure Windows is updated (all patches are applied and no restart is needed). Makre sure you have your codeplugs (if any) saved somewhere else, uninstall the CPS then reboot. Once rebooted go through and delete the following:
C:\Program Files (x86)\Motorola\MOTOTRBO CPS
C:\ProgramData\Motorola\MOTOTRBO CPS
C:\Users\cwh050\AppData\Roaming\Motorola\mototrbocps.tbl
Use a registry cleaner to delete any unused entries then reinstall the (latest) CPS. If this doesnt do the trick, see my support page to get help.
Courtesy of CWH050.blogspot.com
TifosiDonny
What CPS? MotoTrbo?
Yes, for MotoTrbo. And I have read that post about error 1646. But thank you though! :)
kruser
Well Known Member
W St Louis Cnty, MO
Not sure it makes a difference but my version shows 16 Build 828.
I've not had any problems running it on Win10 64 bit but I've since moved all radio software back to a Win7 machine that I plan on keeping just for radio programming.
I would have run the installer or setup file as an Administrator like I always do. I seem to find many programs that don't work correctly otherwise and redoing the install as an administrator usually fixes them. Win10 seems to be very picky about permissions.
