CPS Lock
chrismol1
P25 TruCking!
Oh holy Mother of Moto gods - rain down on me your knowledge of CPS Lock for a HT1250:lol:
Help?
fineshot1
NJ USA (Republic of NJ)
Help?
I guess this is what you are asking about below - this is the only lock reference in the help file.
Radio Lock Password
(Radio Configuration)
DEFINITION:
Selects the four-digit password that the radio requires prior to allowing normal radio operations. The radio-user is prompted to enter this password during radio power-up.
Note: The Menu Items Radio Lock feature allows the radio-user to toggle Radio Lock functionality on and off, and to change this password.
Accessed only:
When Radio Lock field is set to enable, and
when the radio is a portable display model, and
when the radio has a numeric keypad.
Selections:
0000 thru 9999
chrismol1
P25 TruCking!
I have WinHex on right now and typed in an incorrect password and then searched the RAM for Proradio and I have come up with my incorrect password in search but I do not know from there
chrismol1
P25 TruCking!
It is CPS Lock - asks for password when trying to read codeplug
I tried using another codeplug with same model no and saving a password and trying to find on winhex then comparing with the other offset and I dont think I'm doing it right
davidgcet
what exactly are you wanting to know?
you have a CPS password that you have to know to be able to read a radio or open a protected archive. you can write a different codeplug to a protected radio, but of course this overwrites the original programming completely.
then you have radio lock which prevents the radio from being used. this is useful in case the unit is lost, but for most folks is impractical.
i think you can setup a CPS password when installing the software so that without the PW someone cannot even open the software, i know several CPS allow for this but unsure about the Pro. mine is setup without a PW.
also, i have 6.11.10
chrismol1
P25 TruCking!
I have an H1250 AAH25SDH9DU5AN with CPS password - No reading or writing unless you put in a password. I just want to get rid of this password so I can program my darn radio. I purchased it on ebay and the previous shop put a password on the codeplug
I have been pouring over google searches and I found out that you can see the password by using a hex editor program and viewing the RAM in the memory session where I read that the password would be. I have taken a similar codeplug H25SDH9DU5 and put a password on in and tried viewing it in Hex editor. I found where it was - wrote down the offsets and then put my locked radio back up on CPS and opened the hex editor and am searching around trying to find the original password for this locked radio.
This is my first time with hex editor- I read that Find Hex Values... 5B85C0742B and change to 5B85C0EB2B will get rid of the password for my CPS and will allow me to go in an remove the password from this codeplug but I do not know how to change those values. I found them in hex editor but don't know how to change
chrismol1
P25 TruCking!
I'd like to leave this here for future reference if anyone else has this problem and comes along
What you do is get a hex editor program . I used HxD -its free
Then you open file, browse thru program files to where your motorola software is and open Proradio.exe, the green icon
Search for this hex value 5B85C0742B , change 74 to EB
And Save
Open CPS like you normally would, the password box will come up, PRESS Enter and BOOM your in!
Then browse over to the password box and uncheck it, then save and write back to radio and that is it
Password is gone!
This is for CPS Password on Professional Radio CPS
GBLOCK
The Sunshine State
Worked like a charm thanks for help.
Does anyone now if there is a way, using this Hex Editor program, to extend the freq range of a particular code plug or perhaps convert a LS model into a conventional model .....?
chrismol1
P25 TruCking!
Depends. You can extend range depending on the model. Which one were you thinking about?
Also depending on the model, some you cannot and with others, converting a LS to conventional is a job for the depot and don't expect it to be cheap
john1158
Xts5000
OK I have the same exact problem but with an XTS5000. I'm using CPS ver 15.0 but the above method dosn't work.
ck8308
I Have used xir p8260, what Find Hex Values searched need input ? and the below blank list want choose?
I used CPS 8.0
O : Use as wildcard: 3F
Search: ALL
O : COnd :eek:ffset mod
O : List search hits, up to
this all want to prefer?
mdel1189
I have a ht1250ls with a password lock and need it off to program te radio what do I do don't know the password
mdel1189
Understand that but when I look for that value it's not there. That value is in the right colum in hxd program right?
