CPS programming issue
baerenator
Hoping someone can help. Astro portable CPS V 20.01.00, I have been able to program an XTS 5000 VHF radio just fine with ham repeater frequencies and one P25 repeater, this radio was FPP enabled, tested everything works great. My issue is with a UHF and a 900 Mhz versions.First a low UHF XTS 5000 model H18QDF9PW6AN, it should be able to program ham frequencies and I was able to get one UHF simplex frequency, 446.52000 saved in the code plug, but if I try to add a second frequency (even doing the simplex frequency again to test) adding a channel defaults to receive 403.02500 and transmit 378.02500 (which is in red outline since it is outside of the models band split, I can edit them and it will accept the entries and the red outline disappears. Example 443.15000 changes transmit to 418.15000, and I edited to 448.15000. I close and try to save and I get invalid fields box, show it and its transmit frequency, but going to it there is nothing in red or tagged that I can see. I have the same issue with the XTS 2500 for 900 MHz, I can get one entry using a modified pat port.exe but any others give that same type error I see on UHF. A friend flashed an XTS 1500 I have and I can save that initial code plug just fine but if I edit it, it comes back with the same invalid field box with no apparent error I can see on transmit frequency.
Any ideas my head hurts from banging it on my desk.
since you have one that was fine until you put it on your cps, sounds like maybe that CPS setting, picklist or whatever it was in the Options/cps settings, try turning that off if its on
baerenator
Thank you the offset in the option fixed it.
nokones
Sun City West, AZ
You need to set your off-set frequency setting by going to the Frequency Options and set your freq options to ZERO or whatever you want the transmit freq box to populate with when you enter a receive freq. Currently, your Frequency Options must be set for a minus 35 Megs. In the CPS, click on the "View" Tab, click on "options", click on the "Frequency Options" tab, and in the "Offset (MHz)" box, enter your setting value, and click "OK"
