CPS Qustion
bigdoggg
North Carolina
CPS Region Hack Question
I have a copy of the R06.11.05 Professional Radio CPS.
My first question is can I program a HT-750 with this CPS?
My second question is I have been trying to read the radio. I am using a aftermarket USB cable and it is connected and is working fine (have programmed a GP-360 with R06.08.03_EN with no problems). When I try to read the HT-750 I get a "Error 4-1379" "Invalid Regional Code for this CPS version" "Use a CPS version which supports the region of the source radio"
I have found that is has been discussed in the past and that I need to do a CPS region hack however I need someone to walk me through this process step by step. Not familiar with this processes.
I am using Windows XP.
Thanks,
BigDoggg
bigdoggg
North Carolina
But I need some help with this part...
I understand I go to START... RUN... and I enter REGEDIT and push OK.
Then a screen comes up with:
-HKEY_CLASSES-ROOT
-HKEY_CURRENT_USER
-HKEY_LOCAL_MACHINE
-HKEY_USERS
-HKEY_CURRENT_CONFIG
Of course you can expand each.
I need to know which one I need to open and what I am looking for once it is open.
Again I am using Windows XP.
CommJunkie
FN20jf
It's right in the post I linked, man. I can only point you in the right direction, the actual reading and doing it is up to you.
HKEY_LOCAL_MACHINE\SOFTWARE\Motorola\ProRadio\FSK\SerializedString
