Interesting situation developed over the weekend. Was working on the computer when all of a sudden it just shutdown, no blue screen or other info on screen, just turned completely off. Computer is 6 years old.
Turned it back on, started to boot up, then turned itself off again. Let it sit a couple of minutes and turned it back on. It rebooted, so I turned on Speccy to monitor the temps and saw that the CPU temp was running around 140 degrees, when it should have been around 100 while just idling. Watched it and noticed the temp jumping up to around 156-160 while idling, due to background processes running.
Fired up a game because I knew it was an intensive program, and watched the temp soar to over 200 degrees. Bios set to shutdown at 220, which it quickly did.
Ran tests on the Wraith cooler fan and it showed to be running it's normal 2450 rpms. So at this point I knew I had either a CPU issue and possible imminent failure, or the thermal paste had went bad.
Pulled the cooler fan and found the thermal paste to be dry and chalky. Used some 91% alcohol and cleaned the cpu and base of cooler fan. Reapplied new thermal paste and put the cooler fan back on.
Booted back up and while idling the cpu temp was back around 95 degrees. Fired up the game and put it thru it's paces, temp never rose above 126 degrees.
So my advice is to replace the thermal paste on the cpu and fan after about 5 years of service to prevent overheating issues of the cpu.
