ultravista
- Joined
- Sep 19, 2012
- Messages
- 102
My wire antenna has a vertical run of about 30 feet then angles back down, approximately 34-40 feet to an anchor point. The first 20 feet is galvanized fence post. The last portion is PVC. The wire has a few turns around the galvanized pipe and PVC. The wire is clipped to the center threaded pole of the RTL-SDR magnetic base antenna.
I get heavy AM bleed-over everywhere throughout the HF dial using an RTL-SDR V3 dongle sampling the Q-Branch.
How do I get rid of the AM bleed-over? It is terrible and not present at all using a shorter wire thrown over my neighbors tree.
Would the metal pipe, or few turns around the pipe, have anything to do with the AM overload?
