Thanks for checking.
I have the Commercial Radio Services CPS and that does not work either.
I got my hands on a Motorola PMKN4004A RIB to Radio programming cable yesterday however, I am running into a driver issue using my RIB with any radio including my Astro Sabers and XTS3000 radios, and MTS2000 radios.
I have to use a Serial Cable to USB adapter because my XP 32-Bit laptop does not have any serial ports. The Serial Cable to USB with the chip set requires a Prolific driver and that has been working fine for the last 15+ years, but I have a feeling it just may have taken a dump.
I have a couple RIBless USB cables for my MCS2000 and the PMDN4077AR with a single pin that connects to the CT150 radio and Device Manager is happy insofar as no port conflicts using the Prolific driver. When I try to read the CT150 radio with the single pin RIBless programming cable, I get an error that says turn on the RIB or the RIB is not present.
So, when I tried the PMKN4044A RIB cable that has a two-pin Motorola M1 type connector that plugs into the radio yesterday that is when I discovered a Port issue, but after further diagnostics, the RIB works fine for my HT1000, MT2000, and VISAR on my DOS computer setup so it appears that my RIB and Jedi cables are just fine. It has to be down to the Serial/USB adapter cable that may have taken a dump after 15 years of use.
