CW Interval VXR7000
aussierescueil
Central IL
I have a Vertex VXR7000 repeater and currently the unit ID's from an initial input transmission and then 10 minutes later after last transmission or every 10 minutes if using the repeater and the conversations are tying the repeater up for 10 minutes..
Question, are the Vertex able to ID every XX minutes instead, or only ID after last transmission in XX minutes?
(UHF model on GMRS)
TIA
Dave
DylanMadigan
New York, USA
So I'm trying to program mine and I put in the ID but i cant figure out how to get it to transmit the ID on any interval, where in the software did you set that?
mancow
N.E. Kansas
It might be in the extended menu. I can't remember now. I found this over at another web site.
https://hamfiles.co.uk/index.php?page=downloads&type=entry&id=radio-programming%2Fyaesu-programming%2Fyaesu-vertex-vx-7000
In order to put the software in "Dealer" mode, use a -d switch instead of /p after the shortcut target line. Like so: (path details will vary with each pc)
C:\Vertex Standard\CE27 for Windows\CE27Win.exe" -d
This will enable access to adjustments of most parameters in the "Common" menu and also will add three new items under that menu:
Rx Adjustments
Tx Adjustments
Tx Power Adjust
And this also adds an "Adjustment" menu item in HELP.
