this is a windows xp system and I am lost. I paid quite a bit on a scanner to monitor nexedge and at this point I am willing for someone to take control remotely of my computer to help me install what I need to run the DSD software because I can't get it to work. I would be willing to pay someone for their time to help me.
thanks
You shouldn't have paid anything for a scanner to monitor Nexedge, since Nexedge isn't monitorable on any scanner. You could have bought a $10-15 dollar USB DVB-T dongle to use as the source. Oh well, you've already done it.
Do keep in mind that if it is Nexedge trunked, you won't be able to monitor it with DSD. DSD will only decode conventional Nexedge.
You need to learn rather than try and get somebody to log into your computer and do it for you. I'll give you a brief list of things you need to do [which includes what Unitrunker already told you].
If you don't have raw discriminator audio feeding into your computer somehow, don't bother proceeding with anything else. A regular signal from the headphone jack on your scanner to your line-in/mic-in on your computer won't work. You need to have discriminator audio... either from a discriminator tap, a PSR-800 feeding discriminator audio, or some SDR device like a Funcube Dongle or one of the DVB-T dongles). You need to verify that the signal is coming into your computer, and you'll need to adjust the audio on your input device so that it is not too weak and not too strong [i.e. just right].
1. Download hte DSD 1.6.x binary (links are in the RR Wiki)
2. Download and install Cygwin from
Cygwin
3. Set your default sound input and outputs
Start / Settings / Control Panel / Sound And Audio Devices / Audio
- set your default input device to the sound card input that you are getting the signal from
- set your default output device to your speakers (it probably is already set)
3. Open up an MS-DOS Prompt (Start / Programs / Accessories)
4. Nagivate to the folder where you downloaded the DSD.EXE binary to
5. type "dsd --help" to view all of the options
dsd -i /dev/dsp -o /dev/dsp -fi
- for NXDN48
dsd -i /dev/dsp -o /dev/dsp -fn
- for NXDN96
You can hit CTRL-C to stop DSD from running when in a DOS prompt.
If all of that is too much for you, you need to spend the time to learn it.
Mike
