D130j/nj lost set screw
Pape
Quebec
Hello RR,
What was bound to happen happened: I lost one of the set screw (01009) on an Diamond D130j/nj, I'm wondering if any of you know where I can get a replacement ?
Regards
KB0VWG
You might be able to check home depot in the nut and bolts section in the pull out specialty bins
kb0vwg
N9JIG
Sheriff
Moderator
Far NW Valley
Bring another set screw to your local hardware store or home improvement center, they usually have thread sizers there. The owners manual does not list the thread size of the set screws.
I have a D130 in my attic I have had for decades and there are a couple set screws missing that got dropped in the insulation never to be found again. I used regular screws to replace the Allen head screws as I didn't have replacement Allen head screws on hand.
When you find out the thread size please let us know, I might look for some replacements for my pair of D130's to keep on hand.
W8HDU
Lima, Ohio
If it's like the one I have, it's probably going to be a metric. ACE Hardware sells them. Get a stainless even if it costs a buck more.
Ubbe
Stockholm, Sweden
You can use a standard bolt if it is long enough and doesn't need to be that insex type. I think it was a M4 tread.
/Ubbe
Pape
Quebec
Exactly what happened to me, dissembled partially to get it there and reassembly, well you know the story.
I ordered a set of hex screw from amazon will let you know once I have a chance to get back up there.
TerryPavlick
Wallingford PA Villas NJ
I bought the same set off Amazon a while ago. Had same problem with one of my discones. USPS showed up with the package and problem went away.
Pape
Quebec
Installed my last radial today and turn out the set screw is a Din 914 Grub Cone Point Hex Socket M4 X 6mm
I also lost one of the antenna to support pipe and replaced all of them by Hex Socket M3 X 5mm, the original are M3 X 4mm, so now I can work the antenna with only one allen key
