I have 2 AT-D578UV-II's, one at home and the other in the car. The car radio (FW 2.07) is connected to the ignition and so comes on with the ignition. At seemingly random times upon booting it will display:
At first I thought it may have been related to the GPS so I turned that feature off in the menu but the message still appears from time to time.
I press "Confirm" and the radio then boots normally and works fine. (I don't bother actually setting the time and sate as it doesn't matter to me and I don't use APRS etc.)
My home radio (FW 2.06) does not do this and is turned on and off with the power supply probably as much as the car radio. The only other difference I see is that the GPS is not connected.
Has anyone else seen this and have an idea what to do to prevent it?
