darkice.cfg
k7ieu
can anyone post there config to get darkice to properly stream my feed ?
i'm getting an error ( DarkIce: ConfigSection.cpp:117: format missing in section icecast-0 [0] )
here is what i have now
/etc/darkice.cfg
# sample DarkIce configuration file, edit for your needs before using
# see the darkice.cfg man page for details
# this section describes general aspects of the live streaming session
[general]
duration = 0 # duration of encoding, in seconds. 0 means forever
bufferSecs = 5 # size of internal slip buffer, in seconds
reconnect = yes # reconnect to the server(s) if disconnected
realtime = yes # run the encoder with POSIX realtime priority
rtprio = 3 # scheduling priority for the realtime threads
# this section describes the audio input that will be streamed
[input]
device = /dev/dsp # OSS DSP soundcard device for the audio input
sampleRate = 11025 # sample rate in Hz. try 11025, 22050 or 44100
bitsPerSample = 16 # bits per sample. try 16
channel = 1 # channels. 1 = mono, 2 = stereo
# this section describes a streaming connection to an IceCast2 server
# there may be up to 8 of these sections, named [icecast2-0] ... [icecast2-7]
# these can be mixed with [icecast-x] and [shoutcast-x] sections
[icecast2-0]
bitrateMode = abr # average bit rate
format = vorbis # format of the stream: ogg vorbis
bitrate = 96 # bitrate of the stream sent to the server
server = audio3.boradcastify.com
# host name of the server
port = 80 # port of the IceCast2 server, usually 8000
password = PASSWORD # source password to the IceCast2 server
mountPoint = /9jhqv1tc576g # mount point of this stream on the IceCast2 server
name = k7ieu
# name of the stream
description = This is only a trial
# description of the stream
url = K7IEU – Welcome to my ham radio site.
# URL related to the stream
genre = public safety # genre of the stream
public = yes # advertise this stream?
localDumpFile = dump.ogg # local dump file
# this section describes a streaming connection to an IceCast server
# there may be up to 8 of these sections, named [icecast-0] ... [icecast-7]
# these can be mixed with [icecast2-x] and [shoutcast-x] sections
[icecast-0]
bitrateMode = cbr # constant bit rate
bitrate = 96 # bitrate of the mp3 stream sent to the server
quality = 0.8 # encoding quality
server = yp.yourserver.com
port = 8000 # port of the IceCast server, usually 8000
password = hackme # source password to the IceCast server
mountPoint = sample96 # mount point of this stream on the IceCast server
name = DarkIce trial
url = http://www.yourserver.com
genre = my own # genre of the stream
# this section describes a streaming connection to a ShoutCast server
# there may be up to 8 of these sections, named [shoutcast-0] ... [shoutcast-7]
# these can be mixed with [icecast-x] and [icecast2-x] sections
[shoutcast-0]
bitrateMode = vbr # variable bit rate mode
quality = 0.5 # encoding quality
port = 8001 # source port of the ShoutCast server, usually 8001
password = hackme # source password to the ShoutCast server
irc = irc.yourserver.com
# IRC info related to the stream
aim = aim here # AIM info related to the stream
icq = I see you too
# ICQ info related to the stream
DC31
Massachusetts
Assuming that you are just trying to stream to Broadcastify:
[general]
duration = 0
bufferSecs = 5
reconnect = yes
realtime = yes
rtprio = 3
[input]
device = /dev/dsp
sampleRate = 11025
bitsPerSample = 16
channel = 1
[icecast2-0]
bitrateMode = cbr
format = mp3
bitrate = 16
server = audio3.broadcastify.com
port = 80
password = PASSWORD
mountPoint = 9jhqv1tc576g #REMOVE THE LEADING /
name = k7ieu
public = yes
Try the above. Get rid of all the junk you don’t need. No slash in the mount point. Put in your password. I am not sure that you have the device= correct.
k7ieu
[general]
duration = 0
bufferSecs = 5
reconnect = yes
realtime = yes
rtprio = 3
[input]
device = /dev/dsp
sampleRate = 11025
bitsPerSample = 16
channel = 1
[icecast2-0]
bitrateMode = cbr
format = mp3
bitrate = 16
port = 80
password = PASSWORD
name = k7ieu
public = yes
I changed my config to include just the following data and i believe I am all good to go:
[general]
duration = 0
bufferSecs = 10
reconnect = yes
[input]
device = Default
sampleRate = 11025
bitsPerSample = 16
channel = 1
paSourceName = Loopback1.monitor
[icecast2-0]
bitrateMode = cbr
format = mp3
bitrate = 16
quality = 0.1
channel = 1
lowpass = 4000
sampleRate = 11025
port = 80
password = password
name = North Pacific County Police and Fire Dispatch
thank you!
