Darkice on Pi Multiple Streams
With the help of the forums, I was able to successfully get one stream up and running, I have it called darkice1.cfg From my understanding, the only thing I need to do to start another stream was to create a second file called darkice2.cfg, change the password and mount point to the second stream, and then start. I have double and triple checked my cfg file and I'm still getting the error:
$ sudo darkice -c /etc/darkice2.cfg
DarkIce 1.0 live audio streamer, http://code.google.com/p/darkice/
Copyright (c) 2000-2007, Tyrell Hungary, http://tyrell.hu/
Copyright (c) 2008-2010, Akos Maroy and Rafael Diniz
This is free software, and you are welcome to redistribute it
under the terms of The GNU General Public License version 3 or
any later version.
Using config file: /etc/darkice2.cfg
Using ALSA DSP input device: plughw:1,0
Using POSIX real-time scheduling, priority 98
DarkIce: LameLibEncoder.cpp:75: lame lib opening underlying sink error [0]
I feel like I'm missing something very simple.
Running RasberryPi3 Jessy, and again the first stream is working perfectly fine, even on reboots. I don't know what I'm missing.
DC31
Massachusetts
DarkIce 1.0 live audio streamer, Google Code Archive - Long-term storage for Google Code Project Hosting.
Copyright (c) 2000-2007, Tyrell Hungary, Tyrell Hungary Corporation
any later version.
Running a second stream implies that it should be from a second audio source. Is plughw:1,0 the audio source used in both instances? At the command line $ arecord -l will list your audio sources.
I have currently two usb sound cards plugged in. When I run the command to list audio sources I get this:
**** List of CAPTURE Hardware Devices ****
card 1: Device [C-Media USB Audio Device], device 0: USB Audio [USB Audio]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 2: system [iMic USB audio system], device 0: USB Audio [USB Audio]
Subdevices: 0/1
Device 1: For secondary stream, device 2 is for the primary stream. To make it eaiser on everyone, Card 2 serves the PD stream, card 1 serves FD stream. Again, the PD streams just fine.
darkice1.cfg for the PD:
device = plughw:2,0 # hw:0,0 then hw:1,0 then hw:2,0 etc
sampleRate = 22050
bitsPerSample = 16
channel = 2 # 1 for mono, 2 for stereo
darkice2.cfg for the FD:
device = plughw:1,0 # hw:0,0 then hw:1,0 then hw:2,0 etc
sampleRate = 22050
bitsPerSample = 16
I'm assuming that these would be the correct settings. Unless card 1 is required to be inside the darkice1.cfg file...
DC31
Massachusetts
Subdevices: 1/1
Subdevices: 0/1
sampleRate = 22050
bitsPerSample = 16
sampleRate = 22050
bitsPerSample = 16
Try shutting down the PD feed and run just the FD feed. Do you still get the same error?
I wasn't sure how to stop feed one so I just made a copy of my .cfg file, named it copy, then deleted the original. Did a reboot, then ran the command line:
Returned:
any later version.
I then ran to start darkice1.cfg and it ran successfully. But.....
After reboot, darkice1.cfg started successfully, I got the lame error again on darkice2.cfg
