Database Managment
ve3opc
Picton Ontario
Any ideas on a good freeware database that is not the standard table view like access.....I want to design a database that stores tones ,frequencies, locations and various data attached to quirie,...all I find is the table type relational kind while I am seeking field specific retrieval ........Don't want SQL would like something easy to build and use...Thanks...
JoeyC
Senior Member
San Diego, CA
Access will most likely do what you want you just have to build queries (if you don't want code) and forms to gather and present the information. If you are looking at only the tables in Access you are only looking at the bare bones, a mistake many people make when ragging on MS Access. Easy to build, Access not so much.
