Database Submissions
BaLa
4GRC+83; Temple, TX 76502
It used to be when you were looking at a DB Page, and clicked on Submit it would take you to the submission page, and you had to select;
Conventional, News or Trunked, and then Agency I believe.
Now; You have to select Conventional, News, or Trunked.
Then you have to Select the Country, State, County, and Agency.
I think it's a bit tedious to have to Select Country, State and County.
I would like to see that changed back to the way it was before.
thanks.
mtindor
FMP24 PRO USER
Carroll Co OH / EN90LN
Bala,
I suspect you are clicking on Submit Info at the top of the page. What you want to do is click on Submit in the menu on your left when you are inside the DB. For instance, try this:
1. Go to Database Home
2. Select Texas
3. Select Bell County and retrieve it's information
4. Then, on your left you'll see a menu that has an option for Submit.
This is the Submit you would want to click on if you want it to autopopulate the info for you.
The Submit Info button at the top is what I would consider a "generic" submission link since you could be anywhere on the site and access that link - it doesn't know how to populate the info with the state/county/system information that you wish to submit data for. Why? Because you could be accessing that link from anywhere on the site, not necessarily from within the database. When you click Submit in the lefthand menu of a state, county, agency, or system it can populate the information for you automatically.
Mike
