Anyone have the frequencies for the upcoming race?
I am not sure of the trunked system that is used for the County but you may still be able to monitor with a older Scanner as long as it is not Digital or if it hasnt been rebanded .ive been useing my Pro2006 for years to monitor Trunked system'sAnalog will not be a problem. He can also search 450-470 MHZ to get anything missed. With the races there are a lot of businesses here using there own communications system. I pick up a lot when I search the 450-470 range.
If he has an interest in listening to the county he may be out of luck since it is trunked. But for the races he will be fine.
He still might want to buy a frequency list at t he race in the event the one I provided is not accurate. As mentioned before searching 450-470 should find all the drivers.
You can also buy the frequencies at the race. I think you may be able to get your scanner programmed by some of the vendors, but not sure. I'm just passing on things I have read. Here is one site. NASCANNER 2011 NASCAR Nationwide Frequencies, Schedule, and Driver Guide
Here are the frequencies used by the Speedway. I hear these all the time.
464.50000 KD43377 RM 423 DPL NASCAR 1 Operations (Nascar/Fire/EMS/ISC) FM Business
464.52500 KNNN893 RM NASCAR 2 Operations (Nascar/Fire/EMS/ISC) FM Business
463.43750 WNYR592 M NASCAR 3 Operations (Nascar/Fire/EMS/ISC) FM Business
461.57500 WPAJ305 RM NASCAR 4 Operations (Nascar/Fire/EMS/ISC) FM Business
464.41250 WPAC312 M NASCAR 5 Operations (Nascar/Fire/EMS/ISC) FM Business
464.76250 WPAC312 M NASCAR 6 Operations (Nascar/Fire/EMS/ISC) FM Business
461.47500 WPDA956 RM NASCAR 7 Operations (Nascar/Fire/EMS/ISC) FM Business
461.70000 WPIY724 RM 023 DPL NASCAR 8 Operations (Nascar/Fire/EMS/ISC) FM Business
462.75000 WPKN878 BM NASCAR 9 Operations (Nascar/Fire/EMS/ISC) FM Business
464.90000 WYU310 BM NASCAR 10 Operations (Nascar/Fire/EMS/ISC) FM Business
464.77500 WYU665 RM 432 DPL NASCAR 11 Operations (Nascar/Fire/EMS/ISC) FM Business
If I am not mistaken aren't the NASCAR officials using MOTOTRBO for communications or are some NASCAR tracks still using analog?
Nascar ch 1 is Analog the rest are encrypted
