Dead BCD436
sadman3
pickaway county ohio
No the card cannot be read and the scanner or the computer it just won't do nothing I can't get the computer to read it I can't get the scanner to read it when I send a scanner scanner won't go to mass storage mode and it won't go into mass storage mode when its plugged into the computer without it any help appreciated I don't know how to format a card so I'm new at this stuff
D
darunimal
Guest
"No the card cannot be read and the scanner or the computer it just won't do nothing I can't get the computer to read it I can't get the scanner to read it when I send a scanner scanner won't go to mass storage mode and it won't go into mass storage mode when its plugged into the computer without it any help appreciated I don't know how to format a card so I'm new at this stuff"
So let me interpret this
The SD card cannot be read by the computer, even when put into an SD card reader. When you start the scanner it does not do anything at all, its just a blank screen.
Is this a correct interpretation? If yes:
Do you have a SD card reader on your computer?
Which Version of Windows do you have?
Have you ever used the right click on your mouse?
sadman3
Im using a sd card adapter. When i plug the scanner in the screen boots up it shows the first two massages the copyright date then its gives me yhe sd card error. Im using windows 10.
D
darunimal
Guest
With the SD card adapter can you read and write with sentinel?
Voyager
You have yet to confirm that the card is properly formatted as FAT/FAT32. Is it?
sadman3
Ok I have tried new card I formatted fat32. No I cant read and write with card and sentinel. I'm new to this kind of scanning sorry. every thing was working went to update it did come unplugged before I could ejected the scanner and computer that's when I got the message SD card file error use sentinel Clear user Data operation to initialize Sd card. I've done all this over and over. still keep getting same message.
Voyager
Try starting over.
Format the card with FAT32
Use the CLEAR USER DATA in Sentinel
Write the user data to the card.
buddrousa
Is this a brand new card you just removed from the package?
If the above answer is no go buy a new CLASS 10 card and start over.
If you can not read the card in a card reader the scanner has nothing to do with this problem at this point.
D
darunimal
Guest
that didn't work
Which part of the 3 didn't work
1. Format
2. CLEAR USER DATA in Sentinel
or
3. Write to card
because you can't do 2 or 3 without doing 1, Do you know how to see the SD Card in Windows, it's under Computer and its' specified (?) drive letter.
sadman3
I've formatted card with SD formatter then cleared user data. it is a new card I'm using computer drive E II have done all the above over and over,. I'm sure its just something simple I'm missing. Or I have messed something up. I don't know with though. the computer seems to read the new card in drive E. but the scanner don't seem to read card I can not get the scanner to go into mass storage mode at all.. Hope this info is enough to help. I have tried over and over with same results
pjmac
That is the same problem I have problems with. I got fed up with it after two days and sent in to Uniden. Not worth the headache to me.
sadman3
There are no files on card computer was reading card now after it dont want to read it. This is a new card and has been formatted with SD formatter.
buddrousa
Sadman3 would the sd card let you write the data saved in sentinal to the card. If not I email you a copy of one of my scanners and see if that works for you. But that would be latter tonight I have a out of town trip today.
sadman3
Yes the Sd card reads and save data on the computer. That would be greatly appreciated just PM me and I'll see what happens. I don't know what eles to do.
