milcom_chaser
- Joined
- Jul 4, 2010
- Messages
- 989
- Reaction score
- 67
Greetings,
Running FW Version 1.07.09 on BCD325P2.
As per the description: DigitalMobileRadioUpgradeforBCDxxxP2 < UnidenMan4 < TWiki
DMR Reception in Custom or Service Searches
During a search, when the scanner stops on a DMR transmission, the following information will be displayed:
• DMR -- for DMR One-Frequency systems. The scanner will also display the current slot number (S1 or S2) and the received color code.
• CON -- for MotoTRBO Connect Plus systems. The scanner will also display the current slot number (S1 or S2) and the received color code.
• CAP -- for MotoTRBO Capacity Plus systems. The scanner will also display the current slot number (S1 or S2), and the received color code.
• DT3 -- for DMR Tier III Trunked system. The scanner will also display the current slot number (S1 or S2) and the received color code.
We're seeing DMR, CON, CAP being displayed during a custom search. If we change the tone/code search feature to NAC/color we get CC1, CC3, etc.
Not seeing slot numbers S1 or S2 being displayed as described in the Twiki above for custom searches.
Anything else we might have miss in the settings?
Thanks for your help.
