Decoding NAC
Russell
Texas DB Admin
Dallas Texas
When will we see a scanner that will allow us to set, search, and decode NACS on non-trunked P25 channels. I love the 396 and 998 but will not buy another scanner until I can set up NACS for channels the same way we can set PL/DPL on analog channels. Would Uniden be able to add this capability with a firmware update?
Thanks,
Russell
DaveIN
Founders Curmudgen
West Michigan
I think it would take more than a firmware upgrade to decode and display NAC codes.
A service monitor is used in the feild for this and is a costly peice of equipment.
Not saying it can't be done, but most likely not in the current line of digital scanners.
D
DaveNF2G
Guest
There is already software that will do it. Check the other threads in this forum, or search the RR Wiki. I don't think adding the capability to a scanner is going to be as costly as obtaining a service monitor.
N
N_Jay
Guest
Its just some bits in the frame.
All it will take is the manufacturers deciding it is a feature that is worth the software development time.
DaveIN
Founders Curmudgen
West Michigan
Interesting, I had no idea UniTrunker would decode them, but I don't see anything for conventional P25. Is there a seperate program for that?
DaveIN
Founders Curmudgen
West Michigan
Just found it as you posted... No Wiki information yet. Found it after a search and read.
So maybe if enough people brought NAC up with UPMan it could show up in the next Uniden DigiTracker?
