DES - VP8000....
jpajor
Berlin, CT
Anyone have any experience entering DES encryption info (for a secure channel)... I'm assuming software keys but it won't take a key above 10 digits.
D1N for the nx series and Harris rpm2 is pretty straight forward and we use a 16 digit key between the two radios.
Maybe I'm missing something easy.
tweiss3
Is it time for Coffee?
Ohio
Do you mean ARC4 or DES? ARC4 are the only software (armada) loaded keys. DES & AES are either hardware loaded, or KPG-AE1 software loaded. ARC4 allows up to 10 digits, DES allows the 16 digit key. DES cannot be loaded through armada. You do list SLN/Alias in the Global-Lists-Key Table Hardware for all AES&DES keys.
jpajor
Berlin, CT
Sorry I corrected it to just DES, no not arc4... OK, different operation then rpm2 and what the nx uses....
tweiss3
Ohio
Sorta. NX5K allows either DES 4 key (software loaded) or DES/AES multi-key, which require the SCM to be installed and keys to be loaded via hardware or KPG-AE1.
jpajor
Berlin, CT
OK, so I'm clear, with Armada, no way to do a software based des4 single key?
kd4efm
EL98 Florida
You need a VK5000 keyloader to keyload the vikings. KPG-AE1 (or DE1) will not work on vikings.
I have both the Kenwood and Viking keyloaders. If you need more details, you can email me.
If this is for agency use, you need to contact your radio shop to have it done.
jpajor
Berlin, CT
Yep, I hit them up, no issue to add it.... thank for clarifying all!
P25-logger
You can also use the Moto KVL3 and up to load them.
Project25_MASTR
Millennial Graying OBT Guy
Texas
You can use any 3WI keyloader on the Viking radios as long as you have the cables. I've used a HW Ver 1.1 KFDtool, KVL4000 and KVL5000 on my Viking radios (and older 5x00 radios).
