DeWalt two way radio CTCSS and DCS codes
mike619
I was wondering if there was a list of the codes and numbers for the codes in the DeWalt two way radios in a list because they don't show them in the manuals so I was wondering if anyone could help me?
It might help if you had a model number for people to check.
mike619
Did I add the correct tones?
mike619
I updated the tones with it.
K6GBW
Montebello, CA
Couldn't find a list of codes with the corresponding number for those particular radios. That said, if you get the one for Motorola Talkabouts they will be pretty close. 67.0 is always number 1 and as they go up from there they should track pretty close. My group uses GMRS radios with a PL tone of 186.2 and so far that has been 30 on every radio we've brought to the party so I would expect the Dewalts to be the same. It will at least get you close and you can fine tune with others when you use them.
ecps92
Taxachusetts
Post # 5 is 1000% accurate as a cut-paste right from the user manual
But for those who doubt click here
K6GBW
Montebello, CA
That’s the way it comes out of the box. I think he’s trying to find out what pl tone corresponds to the numbers when he changes them so he can make them work with other radios.
mike619
Yes I was wanting to know the tones that correspond with the number of the code in the default settings of the DeWalt radios but I am unable to find them like for instance if DCS number 11 in the default settings is DCS 071 DCS code and so on so that I can program them in my scanner and some other FRS radios for interop.
ecps92
Taxachusetts
Take your scanner, put in the freq with tone search - key up
Guess you may need to make your own list, since these are the only documents found
