Diagnostic data in Unitrunker
Northernblue
Fort Worth Texas
Rick,
I use to use Treport back years ago. I was wondering if the diagnostic data that Treport showed could be incorporated into Unitrunker?
Northernblue
Fort Worth Texas
I can ask Wayne. Is there a reason you stopped using Treport?
I cannot get the program to work on Windows 7 and I like the way Unitrunker works and thought that since the diagnostic data must be in the data stream it would be a nice additional feature for Unitrunker.
campd715
Southeastern Connecticut
If you're monitoring a 3600 baud system, and want to see what's going on with the system including diagnostic data, then give TRUNK88 a try. It's all displayed.
Dennis
cg
Connecticut
I run both UniTrunker and TRUNK88 on Windows 7 with no problem. UniTrunker gives me the multi system types but with much less history immediately available (24 hrs) on the screen. TRUNK88 gives a huge amount of information w/ great logging but is limited to 3600 baud Motorola. Both control many different radio models along with excellant accuracy in each.
chris
The soundcard / windows version of Treport should run on Windows 7. I'll test this out myself this weekend.
Forts
Ontario, Canada
I will 2nd the fact that Trunk88 runs fine under Win7.... No problems at all here. If you see the program start, some stuff scroll by, then it exits... it may be because you need to setup a few parameters first in the .cfg file. It's not that it doesn't like Win 7
Jay911
Silent Key (April 15th, 2023)
Bragg Creek, Alberta
Can someone help me understand what diagnostic data isn't in Unitrunker that is in other programs?
cg
Connecticut
For TRUNK88, it some has additional info and logs it all on the screen as well as in a file.
Just off the top of my head
- RIB / TIB Malfunctions
- affiliation rejections
- all trunks busy vs system busy (no channels available vs radio got rejected)
Also cumulative radio/talkgroup usage data available for each RID/TGID going back as far as your last reset.
System:
- shows how many times each channel was used
- shows how many times the system was fully loaded (all trunks busy)
- shows how many times the system was loaded and another transmission was rejected (system busy)
- total affiliations, deaffiliations, call grants, emergencies, busies, private calls, etc
TGIDS -
- total hits on each TGID and last time used.
- shows TGIDs active on each site and time since last affialition and last use
- logs duration of each transmission
RIDS -
- shows last use (affiliation or transmission)
- shows TGIDS radio was seen on and number of transmissions
I am sure I am missing stuff, this is just what I look at.
chris
WayneH
Forums Veteran
Super Moderator
Your master site
Since TReport has pretty much been abandoned by me I'm hoping the features it provided will get added to UniTrunker. I'm working with Rick to get that to happen. I've got a few other little things I never added to TReport so I may toss those along.
Northernblue
Fort Worth Texas
Do you have any recommendations on how to best set the config file?
