The Discone portion of either version of the 220 is very small and would be in the range of 300-400MHz on up not including the top whip. Not sure what the top whip is tuned for but they would be idiots to tune it in the UHF or higher range where it would interfere with the lower Discone section. At the very least the top whip covers some of the VHF frequency range but the cone elements are too small to provide a good ground plane for the VHF.
Not sure if you caught my post regarding the cone elements or if it makes a diffferene in any of this. But their are six cone elements. Three of them are different than the other three. By different they are a little larger in diameter almost as if they might be fiberglass rod with wire wound elements on them covered in something like heat sink tubing. Looks may be deceiving.
